Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 7 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 2 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 7 Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2 Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2 DD vs dynabel ? - Bilstereoforumet
DD vs dynabel ?
  • GENEXXA
    *********slave
    • Sep 2009
    • 2805
    #16
    Det er jo litt vanskelig og bygge en optimal kasse uten de små paramtrene da Henrik.
    Og DDbox skal jo være "optimal" til alle DD slik jeg har lest på soundpressure.com.
    • DD-Henrik
      • Feb 2009
      • 1947
      #17
      Men det stemmer ikke. Det er en god kasse, men du skjønner vel helt sikkert selv at det ikke går an at kun EN kasse kan være OPTIMAL for tre helt forskjellige elementer (500-serien, 1500-serien og 2500-serien), hvorav 2500 serien er et renspikket SQ element
      DD1515 bør ha rundt 140 liter tunet til rundt 32hz for å spille helt vilt. Når DDBox15 er 100 liter tunet til 40hz er det en vesentlig forskjell men den gir veldig god lyd til å være en fabrikantkasse men ikke noe mer
      Dem kunne selvsagt laget kassen på 140 liter og dem vet jo at det er da den spiller "best" men grunnen til at den er på 100 liter er fordi 140 liter er det ikke alle som har plass til eller ønsker å bruke av plassen sin
      EDIT: Tror nesten du må vise meg hvor det står at DDBox er optimal for ALLE DD subber, for det har ikke jeg sett før. Har sett at det står den er god til 500/1500/2500 serien men ikke at den er god/optimal til 3500/9500 serien. For det er såpass dyre elementer at om man da bruker DDBox har man tappet seg selv unødvendig for mye penger
      overtatt av www.dynaBel.no.
      • Elutstyr1
        • Oct 2026
        #18
        Originally posted by Joakim View Post
        Forsterkeren du linker til er desverre utsolgt hos oss for øyeblikket, men kommer inn igjen om litt.
        Send meg en mail på js@dynabel.no eller ring på 22658070 til uken, så skal vi se om vi kan finne på noe lurt..
        Vi har den på lager enda :-)
        • B&W
          • Jan 2009
          • 63
          #19
          kan du ikke komme med en pakke pris på 2 forsterkere og 2 dd subber
          Besøk vår nettside www.Eikensbilstereo.no
          • Elutstyr1
            • Oct 2026
            #20
            Legg inn en bestilling på forsterkeren, og skriv du ønsker tilbud i kommentarfeltet under bestillingen. Skriv hvilke subber du ønsker tilbud på, så velger du betaling med nettbank, så sender jeg deg et tilbud på mail.
            Selvfølgelig 100% uforpliktende.
            • B&W
              • Jan 2009
              • 63
              #21
              done
