Helix DSP PRO selges billig
  • rwider
    • Dec 2008
    • 9
    Ny Helix DSP PRO selges til god pris!
    Pris: 4500 NOK, Ny helt ubrukt! Inkl frakt!
    The signal processor for all those, who are only satisfied with the best! The new HELIX DSP PRO raises the bar to a new level, not only in terms of sound quality. Due to the implementation of the latest generation of ultra-fast Audio DSPs with enormous 64 Bit resolution, this device provides more calculating power than every other signal processor available on the market today. In addition, it is the first of its kind which performs the full signal path with a sampling rate of 96 kHz, resulting in an extended audio bandwidth up to more than 40 kHz.
    As if that were not enough - the new HELIX Extension Card Slot, simply called "HEC", makes this device extremely flexible and versatile. It allows, by using optional HEC modules, to extend the functionality of the DSP PRO - for example by a Bluetooth® audio streaming module, an additional optical digital input or an optical digital output.
    Entirely new, but still familiar is the completely revised DSP PC-Tool software 3. As intuitive as before, it adds a bunch of new functions and more precise adjustments of all parameters. The real-time analyzer, which is integrated in the software, now comprises the revolutionary "AutoSet" function that makes the equalizer adjustment as easy as possible.
    No doubt - the HELIX DSP PRO will make the dreams come true - even of the most ambitious sound enthusiasts - that´s a safe bet!
  • hc_tk
    • 780
    Er dette Mk2?
    Har den Bluetooth modul?
    Prosjekt SQ Audi A3
    • rwider
      • Dec 2008
      • 9
      Det er ikke mk2, den findes ikke til salg i Sverige endnu..
      Ingen moduler.
      • rwider
        • Dec 2008
        • 9
        4000 NOK ink frakt!
        • hc_tk
          • 780
          får vel fort 25% moms hvis du sender fra sverige.
          Prosjekt SQ Audi A3
          • rwider
            • Dec 2008
            • 9
            afhænger vel af hvordan den sendes tænker jeg ....
