Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 2
Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 2
Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 2
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 2
Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 2
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 7
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2
Ground Zero GZPW 18SPL - MR. BOOMBASTIC - Bilstereoforumet
Sjekk vedlegg med selve testen og rangeringsliste. Utdrag fra testen oversatt til engelsk:
New sound pressure record: The Ground Zero GZPW 18 SPL is a superlative Subwoofer…
…Everything on this yellow glowing monster is made for maximum sound pressure.
…With these results the guys of Ground Zero reached their self targeted goal – scoring 36 points they come to the sound pressure throne again. Standing ovations please!...
…And what about Mister Bombastic’s results in the Sound test?
In short: His performance was just brutal. As the GZPW 18SPL got started in our test Golf, no one could believe it. No matter if short, crisp kicks or profound bass, he shot them all from the hip – as it was just easy going. Talking about Sound pressure, he seems to know no end at all…
…This thing is addictive and it always provokes you to turn up the volume a little more and more…
Wow, this was so cool!...
…With 86 points, the Ground Zero GZPW 18SPL is the best Subwoofer on earth!
"best subwoofer on earth"... Høres ut som en krigserklæring spør du meg GZ er bevist at de er helt RÅE subber, uten tvil, men det finnes mange andre subber de ikke testet også. Men verdens beste?
Men som de sier, "it`s all about the box"
Er sikker på at Alan Dante kunne kjørt en 15" fra Kina til 200kr opp i 160db i sin bil. Synd dem ikke testet flere merker da. Kan nesten se ut som en spons fra GZ med litt betaling for at dem skulle teste produktene dems.
Men GZ er jo stort og kult, så kan jo være moro å prøve det en dag
overtatt av www.dynaBel.no.
Hmmm... du har jo Ascendant Audio, Digital Designs, Fi, RE, Memphis, Soundstream, DC, Atomic, Sundown, Sound solutions audio for å nevne noen. Og alle disse er helt RÅE subber og alle har 18"
Big Oki klarte vel rundt 155 db med sony explods, da har du peiling på hva du driver med når man klarer det med såpass billige og "lav klasse" subber. hadde vært gøy å se Alan Dante tatt en 30 000w burp med en billig 15" da (om den hadde overlevd er en helt annen sak da)
Hvis de er "vant til" å teste 12" subwoofere, er det jo fort gjort at de kan ha blitt "blown away" av hvilken som helst 18"... Husker da jeg fikk igang min første 15" i portet kasse, var forbauset over mengden bass, nesten uten at man kunne se membranen bevege seg.
Hehe, men så hadde jeg litt å lære om DB Drag før jeg skjønte at jeg ikke kunne underbygge fakta jeg påstod. Jeg påstod jo ofte det jeg har fått høre statistisk med scores og lignende.
At du sammenligner meg og de som har testet her blir jo helt feil, da dette er et blad, med folk som visstnok skal være seriøse og gir denne infoen til folk verden over. Var det som jeg fant spesielt merkelig.
Men skjønner hva du mener
Han hadde nok fått hva som helst opp i 170dB, du akn jo regne detg frem til hvor mye effekt det trengs i de bilene for å spille 170 Så Mikko Virta spille over 170dB med to 10" (tror det var cerwin vega) for 4 år siden
hvorfor blir det feil? du skal jo vere en seriøs forhandler/importør av ddaudio i norge og har hatt en del sleivspark i tidligere poster (som du nå selv er klar over) for du hadde lest det en eller annen plass.
men uansett, jeg skjønner hva du mener og du helt sikkert hva jeg mener
Tror det var 2x10" CV Stroker han klarte den scoren med
Cerwin-Vega! Stroker PRO 15
Hifonics XX-Colossus II
Kinetik HC2400 Club 140dB +
