Ny DSP ifra Alpine :D :D
  • Crazytaxi
    • 1170
    Features:
    ImprintEQ
    With fully Manual Tuning built-in, same as F#1 Status and H701, tuning is done via the new RUX or the PC Software. Alpine’s automatic sound tuning technology — Using the supplied omni-directional microphone, measurements are taken from various locations in the car. The resulting data is used to automatically correct any in-car acoustical problems and then apply the desired target sound curve.
    AntEQ
    Removes the factory head unit equalization, leaving a blank slate for these subsequent steps
    Road EQ
    automatically corrects for external noise in real time
    MediaXpander™ Plus
    Improves the playback of compressed media and restores high-frequency audio data
    User Customization
    Gives the user the option to customize the sound via manual or automatic settings – Using either the RUX-C800 controller (sold separately) or a PC with the included tuning software, manual, target curve and post process tuning can be made. The user can customize the sound traditionally by hand or automatically tune it to a desired response, while also allowing for full adjustment for fine tuning afterwards.
    Dual Optical Input
    Ai-Net Input + Ai-Net Aux
    Ai-Net Connection to INA-W910
    Preset, sub Level and Balance/Fader
    6CH Input
    RCA or SPK Input – Up to 10V Input
    8CH Fully Active Output
    4V Output
    10 Band Parametric EQ
    On Front Rear and Center channel (vs 5 on H701)
    5 Band Parametric EQ
    For Subwoofer (vs 2 on H701)
    36dB XO Slopes
    Huge Signal-to-Noise Improvement
    110 Digital / 105 Analog
    Team [B]d[/B]yna[B]B[/B]el
  • Crazytaxi
    • 1170
    Kommer også ny RUX enhet.
    Bilde av den her:
    • Hifonic
      • 2192
      veil pris blir å ligge på 699,95 dollar slik jeg har forstått.
      • Soundboy
        • Apr 2007
        • 619
        Skulle ønske kunne hatt litt bedre ang disse to:
        *8CH Fully Active Output
        4V Output
        F.eks : Kunne sett meg for noe høyere output opptil 8-10V rms!
        *36dB XO Slopes
        F.eks : Mulig for to slope verdi till 48db ,72db/oct , slik som er det på ODR/XES!
